Home > Technical (L322) > Happy New GEAR!! Is it a healthy year for my gearbox? |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 |
I bought them on eba y and from suppliers on the web, sonnax only sells them to its sellers |
4th Jan 2022 4:11pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Did you also do the valves in the pump cover? Because that is a transmisson out job...
4th Jan 2022 4:15pm |
4th Jan 2022 4:16pm |
the first thing you notice is the consumption, the second the speed fluctuates, the engine brake is completely missing, after about 1000 km that I felt the rubbing, the gearbox went crazy, it was climbing and revving and dropping by itself at constant speed.
4th Jan 2022 4:21pm |
https://www.sonnax.com/tech_resources/132-...rse-or-tcc
4th Jan 2022 4:22pm |
I also feel that consumption seems to decline. Revving is most of the time very stable. Only at 70 kmh it sometimes goes up by 50-100 rpm. That yours did go bang in 1000 kms is bad luck. I will keep an eye on how mine behaves. The revving is hardly noticeable. In the mean time I'm going to dive into the Sonnax info you posted. Thank you!
4th Jan 2022 4:30pm |
In the meantime I got a very friendly reply from a Sonnax Product Support Specialist regarding the Accumulator springs: For a RR they only have specs for the #376 plate valve body. The other plate valve bodies #659 and #802 have slightly different springs, but the #376 should do the job in any L322 3.0 D.
6th Jan 2022 3:26pm |
this is interesting |
7th Jan 2022 7:03am |
Now I wanted to see how my box and TCC behave. So I hooked up the IID and recorded a run from stand still (parking place) up the motorway.
9th Jan 2022 4:35pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
The vehicle speeds that you’re mentioning are for the ZF 5HP24 transmission, which doesn’t have a torsional vibration damper in the LUC. The GM 5L40-E torque converter does, so its calibration may be quite different.
9th Jan 2022 7:43pm |
Thanks for your reply Phil!
9th Jan 2022 9:18pm |
Hello Phil, recorded some more files yesterday, but as I came home yesterday my laptop was toasted. Just only could log in with my cellphone but can't load up CSV files. I'm off to work and try to send files in a PM to you tonight. |
11th Jan 2022 7:21am |
Hello Phil,
11th Jan 2022 6:40pm |
Joep,
13th Jan 2022 7:39pm |
