Home > In Car Electronics (L322) > Installing Handsfree in '03 Vogue
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Morning
I have a Bury CC9060 bluetooth handsfree I want to install in my FF
Started yesterday by taking the dash apart only to find that the satnav screen is just a screen really, however I was kind of expecting this
I'm assuming it all needs to be connected via the radio module in the boot, just wanted some advice from anyone whos done it before I jump in and make all the mistakes myself
Does the older radio system have a phone mute/input? When i installed this kit in my last car I used the CC9060's internal amp and a strange loom to cut into the speaker feeds, but there wasn't 13 or however many there is!
All help much appreciated, I'll do a step by step on how to do this as I'm going along
Thanks! 2008/58 FFRR 3.6 TDV8 Vogue
Post #66230 29th May 2011 10:53am
done a quick search and found this..
http://www.fullfatrr.com/forum/topic4644.h...+bluetooth
http://www.fullfatrr.com/forum/topic1987.h...+bluetooth
loads of other stuff there..
Post #66233 29th May 2011 11:36am
dan_uk_1984
I would strongly advise you to consider the OEM Bluetooth solution...
On my last Vogue there was a nokia kit installed already, it muted the radio & nav, but the speaker was in the footwell and sounded terrible. I wanted to upgrade to a system that used the cars speakers but it didn't seem that there was a converter available for the Vogue due to the fact it has DSP, you may find a similar problem.
Doing a quick ebay search for Range Rover Bury, I found this: http://cgi.ebay.co.uk/ISO-SOT-076-k-THB-Bu...3367c085d4
It is worth the £10 to avoid any interference with the factory system, the last thing you want is noise on the line, or to blow the BM54 unit as they are 2-300 to replace.
Post #66234 29th May 2011 11:37am
SteveMFr
Site Sponsor
+1000 Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
(wife thinks I'm nuts - prob right, too)
Post #66236 29th May 2011 11:40am
jonminns
Thanks for your replies
With the cost of the OEM system I'd sooner install my current Bury if possible (especially with various other jobs to do on the car!)
I'll get one of those cables Dan, that's exactly what I was looking for. I never seem to have any luck with finding random cables/adaptors on ebay
Like I said, I'll do a step by step when I work it out so other people find it easier! 2008/58 FFRR 3.6 TDV8 Vogue
Post #66238 29th May 2011 12:17pm
jonminns
I had a crack at it this afternoon and I'm pleased to report I have a fully functioning BT handsfree on the telephone input, best part is I didn't buy a single part - everything I installed was re-used from my Golf
I'll sort out the pictures and do a proper step by step, proper chuffed Very Happy 2008/58 FFRR 3.6 TDV8 Vogue
Post #66295 29th May 2011 11:37pm
Eagerly awaited!
Post #66614 1st Jun 2011 4:10pm
