Home > Maintenance & Mods (L322) > Just bought a 3.6 TDV8, what to do straight away
jazzdude
Cyprus 2007 Range Rover Vogue TDV8 Java Black
Just bought a 2007 3.6 TDV8 with 88k miles on it and want to get things off to a good start with some preventative maintenance.
The previous owner's mechanic said it has been a year since the last service (it had covered about 4k miles since then) and thus recommends we change the engine oil and filters, the cabin, and the fuel filter. He said that about the same time, they had drained the gearbox completely and changed the gearbox oil filter (not mega-flushed) and he said the oil they took out was surprisingly clean, had no metal filings on the magnet, and thus did not think it needed doing again. He also said all the suspension bushes were checked and none needed changing, and it is true there are no knocking noises coming from underneath. The air filter looks like its a K&N type so just needs cleaning.
I intend to blank off the EGR valves this weekend (I already bought them) and will also change the brake fluid while we are at it.
This mechanic told me they also remapped on the car with something from Dimsport (he also tunes cars) and it does indeed fly with incredible amounts of torque, but I am wondering if it would be better to get this redone with someone like Quantum (out here) or BAS remotely (I have a GAP IId).
Any other advice to help me set things up with this car to go towards preventing any future headaches would be very much appreciated
Post #616629 16th Dec 2021 1:38pm
If you're going to do a BAS remap, you can get the EGRs deleted in the map at the same time, as sometimes just blanking them may still result in the engine management light coming on.
Enjoy Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #616631 16th Dec 2021 1:48pm
Gsxr1250dave
Burn it now save you all the heart acke and be cheaper in the long run Laughing
Post #616633 16th Dec 2021 2:03pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
If it is already remapped then why do it again? Just enjoy it as it is. To me that is just wasting money.
Post #616634 16th Dec 2021 2:18pm
jazzdude
I thought about remapping it to a known map rather than something I do not know about, that's all. Smile
Unless all maps are similar that is, then I would agree with you.
Post #616636 16th Dec 2021 2:35pm
mjdronfield
But might be worth doing to ensure EGRs are mapped out properly and blanked off…. Depends on your thought process….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #616641 16th Dec 2021 3:07pm
Bl4ckD0g
Fair comments on both counts.
See how it goes once the EGR are blanked. Most maps are the the same file anyway, lots of places to download and but still a bit of a mystery to some. As long as you aren't expecting further miracles Smile
Post #616651 16th Dec 2021 4:12pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Unless known, I changed transfer box and diffs oil when I had mine. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #616653 16th Dec 2021 4:29pm
nfm
2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Lots of threads on here about preventative maintenance on the rear wheel arches /sill ends: Freelander trim fitting, wax injection etc.
Ps just noted your location; maybe not an issue 😁
Post #616655 16th Dec 2021 4:58pm
JayGee
Low mileage TDV8 in RHD and no rust - sell it to someone in the UK for a tidy profit Laughing 2012 TDV8 Vogue (L322)
Post #616733 17th Dec 2021 2:34pm
jazzdude
Yup completely rust free 👍
Does anyone think that I should try and get the gearbox mega flushed even though last year it had the oil and filter changed?
Would it make that more difference to justify over 400 eu cost?
Post #616750 17th Dec 2021 5:50pm
JayGee
Save your 400 for something else if it’s been serviced last year. If it’s not working properly after a service it’s not the fluid that’s the problem. 2012 TDV8 Vogue (L322)
Post #616751 17th Dec 2021 6:02pm
