Home > Technical (L405) > Adjusting soft close doors |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
found this in an old thread,
14th Dec 2021 5:08pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
The soft close is a motor in the bottom of the door… How it works and how you adjust it I’m not sure? Changed a few that had failed but have never been asked to adjust one… Cant be that difficult though!
14th Dec 2021 5:47pm |
shiversaint Member Since: 16 Aug 2021 Location: Sussex Posts: 9 |
Thanks, this does work to make it kick in, but is not an adjustment of any sort, you have to do this every time... |
15th Dec 2021 9:16am |
Got it, I will have a look. Maybe the cable is stretched or something. |
15th Dec 2021 9:17am |
Silverstone Member Since: 30 May 2024 Location: Silverstone Posts: 23 |
The driver's door soft close does not always work and I would like to lubricate or adjust as required. Is this easy to for someone with very basic DIY skills and if so - what do I do please? "There is no replacement for displacement" - W O Bentley |
5th Aug 2024 1:24pm |
B1GSO Member Since: 10 Jul 2024 Location: Dorset Posts: 1 |
Just had my driver's door soft close repaired. It was the "micro"? switch in the soft close motor so the motor was functioning but the door did not suck closed.
17th Aug 2024 4:28pm |
