Home > Technical (L405) > Adjusting soft close doors
shiversaint
United Kingdom 2013 Range Rover Vogue SE SDV8 Balmoral Blue
Both of my rear doors have tempremental soft close ability, one side worse than the other but neither work consistently.
I think it's just an adjustment thing, the system doesn't seem to realise the doors are half latched.
Question I have is...what exactly am I supposed to adjust? Has anyone done this successfully?
Post #616363 14th Dec 2021 5:01pm
found this in an old thread,
intentionally close the door so that it does not fully close/ seat. Then apply pressure on door handle towards the car as if you are pushing the door inward. The soft close will kick in and close the door. ... - .- -.
Post #616364 14th Dec 2021 5:08pm
The soft close is a motor in the bottom of the door… How it works and how you adjust it I’m not sure? Changed a few that had failed but have never been asked to adjust one… Cant be that difficult though!
Remove the door card and look in the bottom of the door and you’ll find said motor on an 18” cable assembly… 👍
Post #616371 14th Dec 2021 5:47pm
shiversaint
Thanks, this does work to make it kick in, but is not an adjustment of any sort, you have to do this every time...
Post #616440 15th Dec 2021 9:16am
shiversaint
Got it, I will have a look. Maybe the cable is stretched or something.
Post #616442 15th Dec 2021 9:17am
Silverstone
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
The driver's door soft close does not always work and I would like to lubricate or adjust as required. Is this easy to for someone with very basic DIY skills and if so - what do I do please? "There is no replacement for displacement" - W O Bentley
Post #697441 5th Aug 2024 1:24pm
B1GSO
Just had my driver's door soft close repaired. It was the "micro"? switch in the soft close motor so the motor was functioning but the door did not suck closed.
Cost £489 motor & labour 😓
Post #698253 17th Aug 2024 4:28pm
