![]() | Home > Maintenance & Mods (L405) > Car finally delivered!! - Which C-Tek Charger for a 5.0 S/C |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 742 ![]() ![]() ![]() |
Unfortunately the tow bar adapters aren’t available from the site shop anymore due to component shortages. 2021 P400 Silicon Silver AB Gone 2011 Bournville TDV8 VSE Gone 2008 Black Canadian HSE LUX |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
That a beauty aja, love the spec. |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
Thanks caymanblack, I'm glad you like it. I understand my colour choice is not to everyones taste and that more black accents are popular nowadays, but I think it looks quite simple, clean and elegant.
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 788 ![]() ![]() ![]() |
I’ve not used my Ctek, even throughout the lockdowns, since I bought an Optimax Solar charger. The original reason for a solar charger was because I often leave the RR at the airport for a month. It also saves faffing about connecting the Ctek up to the mains.
Thanks Phil - That's interesting, sounds particularly good for airport parking.
I use the same battery connector as above for both the Cteck and Optimate. Although you may need an extension lead if you run the lead for the solar panel through to the front windscreen. MY23 D350 HSE
Thanks Phil |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Looks lovely Aja, look forward to meeting you when we turn her into the dog wagon/uber |
Definitely, thanks Craig |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Either 5A or 10A CTEK work fine on my twin battery Westie.
