Home > Maintenance & Mods (L405) > Car finally delivered!! - Which C-Tek Charger for a 5.0 S/C
knwatkins
Don't connect directly to the battery. You'll be bypassing the BMS so it won't account for the charge being applied to the battery. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #615127 7th Dec 2021 8:01am
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
MPx wrote:
Do you have the deployable tow bar? If so then I'd second MJDronfield and advise using that with a connector from the site shop and the CTEK 5. That's what I do and it works well. Advantages include: not having to get at the battery or terminals which are quite well hidden away; regularly exercising the tow bar mechanism which is liable to stick if ignored for months/years on end; and all cabling external to the car so no seal strip deformation.
Unfortunately the tow bar adapters aren’t available from the site shop anymore due to component shortages. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #615132 7th Dec 2021 8:59am
caymanblack
That a beauty aja, love the spec. Thumbs Up
Post #615212 7th Dec 2021 5:30pm
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
Thanks caymanblack, I'm glad you like it. I understand my colour choice is not to everyones taste and that more black accents are popular nowadays, but I think it looks quite simple, clean and elegant.
Thank you knwatkins, I was going to insert below the top nut as per the video below at 4.32 - Will it be OK if I do it that way and leave the connector on at all times:
Video example:
(see 4.32)
Connector:
https://www.halfords.com/motoring/battery-...html?_gl=1*148n7qd*_up*MQ..&gclid=EAIaIQobChMIkcTzjdrN9AIV_IBQBh3AuQi8EAQYASABEgKIF_D_BwE
Post #615241 7th Dec 2021 10:09pm
Phil.
I’ve not used my Ctek, even throughout the lockdowns, since I bought an Optimax Solar charger. The original reason for a solar charger was because I often leave the RR at the airport for a month. It also saves faffing about connecting the Ctek up to the mains.
I connect mine directly to the main battery in the boot using the same connector as above. Then run a wire between/under the rear seat/carpet then down the side of the passenger seat, popping the panel on the dash when required. It’s easy to unplug the panel from the side of the passenger seat and pop it in the boot when not required. Or if it’s just me driving then I drop it in the passenger footwell.
Unlike other solar panels the Optimate regulates the current a bit like a Ctek to meet the needs of the battery.
I use the 10W version but this 20W would probably be better:
https://www.motohaus.com/optimate-solar-20...eries.html
I have connected my Ctek and solar charger to the battery for years on several 405’s with no issue. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #615262 8th Dec 2021 9:08am
aja500
Thanks Phil - That's interesting, sounds particularly good for airport parking.
I returned to my old L322 at Gatwick early one December morning after a long haul flight home, only to find that the battery was flat. What then followed was a long cold wait for the AA, not something I want to repeat, so will definitely look into that.
Does the CTEK comfort connector still fit under the battery nuts in the same way with both chargers?
Post #615408 8th Dec 2021 8:06pm
Phil.
I use the same battery connector as above for both the Cteck and Optimate. Although you may need an extension lead if you run the lead for the solar panel through to the front windscreen. MY23 D350 HSE
Post #615421 8th Dec 2021 10:00pm
aja500
Thanks Phil Thumbs Up Thumbs Up
Post #615430 8th Dec 2021 11:40pm
Looks lovely Aja, look forward to meeting you when we turn her into the dog wagon/uber Thumbs Up
Post #615435 9th Dec 2021 12:20am
aja500
Definitely, thanks Craig Thumbs Up Thumbs Up
Post #615533 9th Dec 2021 6:06pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Either 5A or 10A CTEK work fine on my twin battery Westie.
The NOCO GB150 I bought before fitting the twin layout is now kept in the boot just in case,
Belt n Braces ? OTT ? Probably but don't need the aggro again of a non start with caravan on back Embarassed . Forty years of progress. 1972-2012
Post #615703 10th Dec 2021 3:40pm
