Home > Maintenance & Mods (L322) > Coolant Leak 4.4 TDV8
V8_Disco
So odd one
My 2011 VSE has a coolant leak, it’s small and it’s not mixed with oil etc and the oil cooler pipes have been done in the last 2 years
No oil in the coolant, truck was parked a week while we used another car for a holiday, before that it had been used a fair bit while the other car was down for parts (thanks Subaru)
Jumped in it to low coolant warning, topped up and it seams to be loosing a dribble a day - JAS my local independent is booked up for ages - like months!
Any ideas? I will have to look over the weekend as with work its dark etc
Cheers
Post #614485 2nd Dec 2021 7:03pm
JayGee
Remove the under trays and have a look if you can see coolant. Put newspaper under the engine after a drive and leave overnight to see if there is any staining in the morning. You don’t need a specialist Landrover garage to find a leak so if you don’t want to DIY take it to any competent mechanic. 2012 TDV8 Vogue (L322)
Post #614491 2nd Dec 2021 7:19pm
V8_Disco
Yep going to look at that on sat, I don’t trust half of the shops around this way - it’s just rubbish timing I have a chunk of my mba coursework to do in December- hoping I could push money into it to resolve it without to much faff
Wondering if there where any other odd things that go (like the cooler) that might put me ahead a bit
Post #614492 2nd Dec 2021 7:25pm
DrRob
Most decent garages can do a coolant leak pressure test. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #614497 2nd Dec 2021 7:34pm
DrRob
Joe at JAS sends his apologies for not being able to fit you in. Busy guys! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #614500 2nd Dec 2021 7:53pm
V8_Disco
Yeh they where great on the phone just really busy, because they are very good!
Post #614503 2nd Dec 2021 8:03pm
