![]() | Home > Maintenance & Mods (L322) > Coolant Leak 4.4 TDV8 |
Remove the under trays and have a look if you can see coolant. Put newspaper under the engine after a drive and leave overnight to see if there is any staining in the morning. You don’t need a specialist Landrover garage to find a leak so if you don’t want to DIY take it to any competent mechanic. 2012 TDV8 Vogue (L322) |
V8_Disco Member Since: 24 Dec 2020 Location: Yorkshire Posts: 101 ![]() ![]() |
Yep going to look at that on sat, I don’t trust half of the shops around this way - it’s just rubbish timing I have a chunk of my mba coursework to do in December- hoping I could push money into it to resolve it without to much faff
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Most decent garages can do a coolant leak pressure test. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Joe at JAS sends his apologies for not being able to fit you in. Busy guys! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Yeh they where great on the phone just really busy, because they are very good! |
