![]() | Home > Technical (L322) > 2012 Westminster Gearbox issues |
Not a very common issue no sir... Have you a fault code reader? It might have just thrown a wobbler?
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 ![]() ![]() ![]() |
Thanks Craig, I'll give that a go tonight when I get home. Even with the engine running can that still throw up battery issues? Seems strange for it to suddenly occur. The car done around 400 miles on Fri/Sat with no problems at all.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
check battery and read codes then clear, you might get lucky.
https://automaticman.co.uk/
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Martin Hind at Dartford Transmissions might be worth a call.
The mystery deepens... left the car idling for around 20mins this morning to allow everything to warm up. Upon turning the engine off and switching it back on, everything came back to life, car drives normal.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
On every L322 we've had, whenever the battery voltage gets low the first error message to come up on the screen is gearbox fault.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
i think its a battery problem as well....check that and the charging system .. ... - .- -.
Battery last replaced 2019 I believe. A leak on the steering rack KO'ed the alternator beginning of the year so that was replaced around March time.
I have had batteries die in 2-3years, usually still under warranty so might be worth getting it checked and if its done in they will send you out a new one.
Yep, clip the MXS-5 onto it and wait until it tells you the battery is fully charged then see if you get any issues over the next few days. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I think Baltic Blue (Mike) had this issue after being away for a bit. Battery IIRC.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Mine was stuck in P Greg after standing for 4 weeks whilst I was away.
