![]() | Home > Maintenance & Mods (L322) > Help on Adaptive Dynamics Please |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
Have you replaced the wires front and back? Time is definitely up on the back ones too. |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
No issue replacing the rear ones as well. What I was hoping was someone confirming they had the same fault code regarding the module error, especially if they had a wire issue. |
Replaced the Control Module and thankfully all back working as it should. |
mtaggart Member Since: 13 Feb 2023 Location: Washington State Posts: 2 ![]() ![]() ![]() |
Did you have to reflash the control module when you replaced it? |
