Home > Maintenance & Mods (L322) > Completely seized wheel nut
Tattiepicker
United Kingdom 2011 Range Rover Vogue TDV8 Mariana Black
Any tips on how to remove a completed seized and rounded wheel nut. Whoever put on this wheel is an absolute whopper. Tried a reverse thread bolt remover with split instantly.
Post #613163 19th Nov 2021 3:55pm
JayGee
Heat + impact driver. If a 12 point socket rounded it off use a 6 point. 2012 TDV8 Vogue (L322)
Post #613165 19th Nov 2021 4:06pm
Tattiepicker
None fit anymore I’m afraid. Not sure if I recovery socket adapter would withstand the torque that is on it to remove.
Post #613167 19th Nov 2021 4:15pm
this kind of situation is a pain....i would find an old impact socket which is slightly smaller than this nut and bang it on with a hammer...then either a breaker bar or high powered impact wrench to try and shift it..good luck. ... - .- -.
Post #613168 19th Nov 2021 4:18pm
JayGee
Seized nuts and bolts respond better to impact than torque IME (torque has obviously failed here). You need to send shock waves through the nut to break the friction.
This is also why wheel nuts have torque settings and not hard-as-you-can-with-a-breaker bar....... 2012 TDV8 Vogue (L322)
Post #613170 19th Nov 2021 4:24pm
Tattiepicker
Cheers Stan, worked a treat. Thought I was going to snap the threaded bolt
Post #613171 19th Nov 2021 4:49pm
JayGee
Great news! 2012 TDV8 Vogue (L322)
Post #613172 19th Nov 2021 4:54pm
Tattiepicker
Sacrificed a brand new 20mm socket though 🥲
Post #613173 19th Nov 2021 4:56pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Cheap for what it could have cost Whistle
Post #613174 19th Nov 2021 5:26pm
nice job Matt.. Thumbs Up ... - .- -.
Post #613190 19th Nov 2021 7:16pm
p38arover
Australia
Thank goodness it wasn’t a locknut! Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #613204 19th Nov 2021 9:31pm
