Home > Technical (L322) > Steering wheel height adjustment
Nespouls
France 2007 Range Rover Vogue TDV8 Adriatic Blue
I had to replace my steering column because of a faulty steering column lock. The job is more daunting than it is difficult. With some patience, and a reasonably good tool supply, it is relatively straight forward. I bought the replacement column from a UK breakers yard on eBay for about 150GBP.
Incidentally, if you do go down this route it is well worth doing some preventative maintenance on the replacement shaft before installing it. The reason my steering lock failed was because the grease in the worm-drive gearbox had turned to concrete. By removing the roll pins retaining the cover it is very easy to dismantle the gearbox and re-lube it.
Also, when you receive the replacement steering column you can test that all is working by removing the plastic covers around the steering wheel and accessing the electrical connector. There is sufficient length in the loom to allow you to plug in the replacement with the existing column in situ. When it works, it gives you a warm feeling . . . . !
Good luck!
Stuart Stuart
L322 2007 TDV8 Vogue
Post #614385 1st Dec 2021 2:42pm
Grayson Welly
Well done Stu, that sounds very satisfying.
Interestingly enough, an indy told me that the issues are probably memory rather than motor related. He suggested changing the memory settings by pressing '2' through the cycle and then the option of preference. Sure enough, the steering wheel hasn't dropped since then!
The button to lower the suspension isn't working either (the one located on the driver's door), I wonder whether this is an issue with MOST? --------
2006 Buckingham Blue/Parchment White AJV8 Vogue
Post #614406 1st Dec 2021 5:24pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Dont think i have used mine since i bought it....................... Laughing
Post #614410 1st Dec 2021 5:58pm
Grayson Welly
How do you even get out of your driveway? Wink --------
Post #614413 1st Dec 2021 6:36pm
