Home > Technical (L322) > Fault Codes - sanity check |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Pretty normal. The only thing I would look at is the gallery venting issue.
18th Nov 2021 1:11pm |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 |
I'll do that once the compressor is replaced, thank you.
18th Nov 2021 1:44pm |
You can unbolt the filter without disabling anything. It's a 17mm spanner only. Christian.
18th Nov 2021 1:48pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
A few of us replied on your other thread about some of the codes e.g. P040D
Yup - that's why I specifically mentioned that code and that I'm not going to do anything about it at the moment 2011 4.4 TDV8 Vogue SE - 'Black Betty'
18th Nov 2021 2:04pm |
