![]() | Home > Technical (L322) > Fault Codes - sanity check |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 ![]() ![]() ![]() |
Pretty normal. The only thing I would look at is the gallery venting issue.
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
I'll do that once the compressor is replaced, thank you.
You can unbolt the filter without disabling anything. It's a 17mm spanner only. Christian.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
A few of us replied on your other thread about some of the codes e.g. P040D |
Yup - that's why I specifically mentioned that code and that I'm not going to do anything about it at the moment |
