Home > Maintenance & Mods (L405) > AGM setting on CTEK |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
Looking at the top of the battery will confirm if its AGM or not. I don't know - I suspect it is but having a look is a 2 min job but needs the compressor unbolting. it simply lifts out of the way. 405 AB exec seats Baltic and Cirrus
13th Nov 2021 6:32pm |
Marcus Member Since: 04 Jun 2021 Location: London Posts: 11 |
Many thanks - much appreciated, will take a look. |
13th Nov 2021 6:40pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
I agree that AGM is probably what is fitted. My 2011 car has AGM.
13th Nov 2021 7:18pm |
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 |
Hi Marcus
13th Nov 2021 8:01pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
It'll be an AGM battery so yes, use the AGM setting on your CTEK and connect to posts in the engine bay. Kev
13th Nov 2021 9:41pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
All JLR batteries have been AGM since circa 2009 guys |
14th Nov 2021 12:35am |
Hi Craig - assuming its an OEM spec battery. Could it be possible to use a non-AGM replacement?
14th Nov 2021 10:07am |
No sir it’s not, it’s designed for AGM use only sir… Quite what the outcome would be I’m unsure as I’m no Battery expert sir… |
14th Nov 2021 10:50am |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 740 |
Think it was 2011 when the switch was made to AGM ? my 2011 started with a normal battery and was switched out to AGM fairly quickly when early 2011's were all having battery issues. 2021 P400 Silicon Silver AB Gone 2011 Bournville TDV8 VSE Gone 2008 Black Canadian HSE LUX |
14th Nov 2021 12:10pm |
Thanks everyone - fantastic responses and AGM mode now duly set! |
14th Nov 2021 12:22pm |
