Home > Maintenance & Mods (L405) > AGM setting on CTEK
Marcus
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
AGM setting on CTEK
Hi all - I have a 2015MY AB 5.0 S/C and have just purchased a CTEK MXS 10 to keep the battery tip top... should I use the AGM setting on the charger? Not had a look at the batteries... the car has start/stop if that makes a difference.
Thanks in advance!
Post #612520 13th Nov 2021 5:59pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Looking at the top of the battery will confirm if its AGM or not. I don't know - I suspect it is but having a look is a 2 min job but needs the compressor unbolting. it simply lifts out of the way. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #612523 13th Nov 2021 6:32pm
Marcus
Many thanks - much appreciated, will take a look. Thumbs Up
Post #612527 13th Nov 2021 6:40pm
mjdronfield
I agree that AGM is probably what is fitted. My 2011 car has AGM.
Used the CTEK for years without issue.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #612532 13th Nov 2021 7:18pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi Marcus
I have a 3.0 2014 l405.
I have the exact same charger and I just connect mine in the engine compartment. All work and chargers well.The extension flex cable I position near the headlights and find shutting the bonnet not an issue.
I use the AGM setting and the charger run it cycle until the green led. I have left mine connect for two days and no issues.
Post #612542 13th Nov 2021 8:01pm
knwatkins
It'll be an AGM battery so yes, use the AGM setting on your CTEK and connect to posts in the engine bay. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #612557 13th Nov 2021 9:41pm
All JLR batteries have been AGM since circa 2009 guys Thumbs Up
Post #612575 14th Nov 2021 12:35am
ajac8
Hi Craig - assuming its an OEM spec battery. Could it be possible to use a non-AGM replacement?
I have no idea. Bow down 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #612594 14th Nov 2021 10:07am
No sir it’s not, it’s designed for AGM use only sir… Quite what the outcome would be I’m unsure as I’m no Battery expert sir… Thumbs Up
Post #612599 14th Nov 2021 10:50am
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Think it was 2011 when the switch was made to AGM ? my 2011 started with a normal battery and was switched out to AGM fairly quickly when early 2011's were all having battery issues. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #612617 14th Nov 2021 12:10pm
Marcus
Thanks everyone - fantastic responses and AGM mode now duly set! Thumbs Up
Post #612619 14th Nov 2021 12:22pm
