Home > Technical (L322) > P040D and restricted performance 4.4Tdv8 … red herring?? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
You won't clear a red with P040D in place.
11th Nov 2021 12:47pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I have had that fault ever since I’ve owned my 11 4.4.
11th Nov 2021 12:50pm |
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 |
The weird thing is that although it’s a red fault it’s not a red dpf fault which I know would/could be a hindrance to a forced regen. I have never seen an amber DPF specific fault or the red “contact dealer” fault.
11th Nov 2021 1:05pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
I agree
11th Nov 2021 1:13pm |
Hi Mike,
11th Nov 2021 1:24pm |
If you put up a photo of the plenum , just with the plastic engine cover removed, I will confirm hoses.
11th Nov 2021 2:01pm |
Dazzab1972 Member Since: 13 Dec 2018 Location: Orpington Posts: 9 |
I have a similar issue.
11th Nov 2021 2:21pm |
Dazzab1972 Are they sure the sensor is causing the issue or is it that it has failed like most others and showing a fault code?
11th Nov 2021 3:54pm |
So I’ve been reading up on the fault codes
11th Nov 2021 6:04pm |
The high pressure smoke test came back with no issues so I have been focussing on P2452-95 as that seems the logical culprit.
12th Nov 2021 6:44pm |
Best decision to get an IID Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Nov 2021 12:56pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
I believe the P040D code simply means the temp probe has a fault! some may fail in a near normal state and cause the engine to run normally, some may fail in a cold state causing the engine to over fuel (trying to gain temp) this will then fill the DPF with unburnt fuel, and voila DPF issues...
14th Nov 2021 12:49am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
1. As others have said you can leave the sensor, change it if you want - but it's not causing your RP
Answer: a lot 4. Smoke tests do not always show the leaks, not sure why I've had first hand experience with all above points so suggest you look at the four donut hoses and also the throttle body connection (which you have flagged) and also the CSOV valve. All searchable right here on the forum. Good luck Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
14th Nov 2021 7:27am |
The saga continues:
17th Nov 2021 11:57am |
