Home > Maintenance & Mods (L322) > Locked out of my 2011 RR Vogue
Page 1 of 3 123>
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Alarm sounded the other day, when locked and parked on drive. It would not stop using key fob, so connected battery charger to towing socket luckily silence.
So I thought battery must be flat as was working on it a couple of days before. After leaving charger on for several hours and getting a decent voltage on charger, tried opening with fob NOTHING!
I have tried emergency key in door, barrel turns both ways but does not unlock. Have had charger on for a couple of days, battery is holding some charge as alarm does not go off during night. Still getting no reaction when fob is pressed (changed battery in fob also just in case it was that).
Just a note battery went flat during lockdown last year summer with no alarm sounding, put charger on, managed to unlock after a few hours. Has worked ok ever since until now.
Open to any suggestions guys. -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #609060 13th Oct 2021 7:02pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Have you tried tailgate button on key fob? Try holding the open button on and see if it opens the windows. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #609074 13th Oct 2021 9:24pm
Fox889
Stupid suggestion coming.............have you tried the second key fob [assuming you have 2 keys]?
If this doesn't work.....how the heck do you get in???? Jeeeez sounds worrying. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #609091 14th Oct 2021 7:29am
Giffer2018
V8 Bob, I have tried all buttons on fob, no joy.
Fox889, yes have tried other key fob.
When I tried again last night, I noticed that the dashboard background energises when the unlock button is pressed, then goes off again. So that makes me think that the key fob is still talking to the RR, but not enough to open it. -----------------------
Post #609096 14th Oct 2021 8:57am
i reckon the main battery needs replacing...you say the charging has brought it up to voltage but it could be that a drop test will reveal dead cells.. ... - .- -.
Post #609097 14th Oct 2021 9:03am
kevinp
I know this might not be relevant, but I had a Ford Explorer that wouldn't unlock if I was near a transmitter tower. I found the receiver on the car was in the rear wheel arch and if I hovered the remote right next to the metal of the wheel arch it would work. Can you find where the receiver location is on our your car and try it?
Post #609098 14th Oct 2021 9:09am
GraemeS
Australia 2012 Range Rover Autobiography TDV8 Bournville
Have you tried unlocking while the battery charger is connected, either to the white socket or onto the power lead at the starter motor?
Post #609099 14th Oct 2021 9:58am
The mechanical key should work unless it is the wrong key, if it turns then it's the right key, it does take quite a bit of force to unlock the door, give it another go and turn harder.... just be aware you can snap the key if the lock is broken in some way... Thumbs Up Pete
Post #609106 14th Oct 2021 10:46am
Have you considered that whilst you have a charger connected to the tow socket there may be corrosion in the tow socket connections inhibiting any charge voltage getting to the battery, the earth connection is the usual suspect. If you have a charger connected to the tow socket l would expect the locking to work irrespective of the state of the battery, unless of course there is an unrelated locking fault.
Post #609129 14th Oct 2021 2:19pm
Baltic Blue
I agree with Nicedayforit’s concerns.
I spent ages trying to resolve a charging problem through the white tow socket.
It was showing 13 volts on the socket end monitor, but barely 12v at the battery terminals until I found 2 suitable sized drills and cleaned out the female holes in the socket.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #609144 14th Oct 2021 3:29pm
Giffer2018
Thanks for your replies.
Stan, battery is less than 2 years old but second time it's been flattened. problem is I cannot open bonnet to get to it.
kevinp, have tried fob in several places.
GraemeS, tried that.
Haylands, key turns 90* both ways, then I get resistance.
nicedayforit, battery charger does test and seems to be working ok, plus alarm stopped when I first connected it, so assume power is getting throu.
Just to update you all,
Had Green Flag out, he immediately said battery. He did not manage to unlock it, said emergency key mechanism must not be connected in door. Only option he offered was dealers.
Spoke to a Landrover specialist, said seeing emergency key not working, they would have to smash a window and climb in to release bonnet!!
Surely they must be another way to open bonnet or tailgate???
I am now very disheartened with my 18 months of ownership. -----------------------
Post #609148 14th Oct 2021 3:48pm
this is from our wiki, have a read ,
https://www.fullfatrr.com/forum/topic38460.html ... - .- -.
Post #609152 14th Oct 2021 4:01pm
You will probably have laminated side glass so all your windows will be very hard to break enough to get in...
If you really have to I'd wreck the grille and pop the bonnet that way... although the alternator connect on Stans link looks like the best idea...
Good luck Pete
Post #609154 14th Oct 2021 4:09pm
"nicedayforit, battery charger does test and seems to be working ok, plus alarm stopped when I first connected it, so assume power is getting throu."
Given that you can't get in the car l would assume nothing personally. Wink
The alternator connection is worth trying if you can get under the car.
Post #609163 14th Oct 2021 4:48pm
Merchy
Not on a RR, BUT had a Navara stuck in my garage, completely dead battery and getting to the door lock with the key was impossible as the passenger side was 3 inches off a wall, same with front end.
Makers ( Nissan UK head office ) said smash the cheapest window Shocked called AA out, we jacked the Navara up, connected a jump starter pack to the chassis and starter motor, that put enough current in to operate the central locking, then we could drag it out of the garage.
I would check first, but just an idea? Hope this helps Thumbs Up
Post #609180 14th Oct 2021 5:35pm
Page 1 of 3 123>
