Home > Maintenance & Mods (L322) > Locked out of my 2011 RR Vogue |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Have you tried tailgate button on key fob? Try holding the open button on and see if it opens the windows. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
13th Oct 2021 9:24pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
Stupid suggestion coming.............have you tried the second key fob [assuming you have 2 keys]?
14th Oct 2021 7:29am |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 52 |
V8 Bob, I have tried all buttons on fob, no joy.
14th Oct 2021 8:57am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
i reckon the main battery needs replacing...you say the charging has brought it up to voltage but it could be that a drop test will reveal dead cells.. ... - .- -.
14th Oct 2021 9:03am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
I know this might not be relevant, but I had a Ford Explorer that wouldn't unlock if I was near a transmitter tower. I found the receiver on the car was in the rear wheel arch and if I hovered the remote right next to the metal of the wheel arch it would work. Can you find where the receiver location is on our your car and try it? |
14th Oct 2021 9:09am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Have you tried unlocking while the battery charger is connected, either to the white socket or onto the power lead at the starter motor? |
14th Oct 2021 9:58am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8191 |
The mechanical key should work unless it is the wrong key, if it turns then it's the right key, it does take quite a bit of force to unlock the door, give it another go and turn harder.... just be aware you can snap the key if the lock is broken in some way... Pete
14th Oct 2021 10:46am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Have you considered that whilst you have a charger connected to the tow socket there may be corrosion in the tow socket connections inhibiting any charge voltage getting to the battery, the earth connection is the usual suspect. If you have a charger connected to the tow socket l would expect the locking to work irrespective of the state of the battery, unless of course there is an unrelated locking fault. |
14th Oct 2021 2:19pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
I agree with Nicedayforit’s concerns.
14th Oct 2021 3:29pm |
Thanks for your replies.
14th Oct 2021 3:48pm |
this is from our wiki, have a read ,
14th Oct 2021 4:01pm |
You will probably have laminated side glass so all your windows will be very hard to break enough to get in...
14th Oct 2021 4:09pm |
"nicedayforit, battery charger does test and seems to be working ok, plus alarm stopped when I first connected it, so assume power is getting throu."
14th Oct 2021 4:48pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Not on a RR, BUT had a Navara stuck in my garage, completely dead battery and getting to the door lock with the key was impossible as the passenger side was 3 inches off a wall, same with front end.
14th Oct 2021 5:35pm |
