![]() | Home > Technical (L322) > Advice on error codes |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
There'll be a pipe from the second turbo down to the engine block, right pain in the 'arris to see even laying on your back looking upwards.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
This thread provides all the info. & pictures of what you’re looking for-
AFAIK it only prevents smoke and is not a preventative fix against a major component fail. You have a 30 day window when buying a used car to reject it on the grounds of it being faulty or having significant faults that the dealer has to rectify so again I'd strongly suggest you get it inspected by a LR indy specialist so you know what you are dealing with. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
It involves drilling into the sump. Swarf risk. Personally, it's not worth the risk if you have a non-smoker. Save your cash for other work as it crops up....see my list ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
IGNORE Dr Rob beat me to it
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Fair enough and point taken on board; I'll give it a miss for now,. Thanks! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
So, I've replaced the compressor this evening and cleared the faults but unfortunately, still not working.
Update; was the wiring to the compressor. Had rubbed through on the box and split 1 wire and shredded another 2. Cut out, resoldered, job done! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
