Home > In Car Electronics (L322) > Audio help
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Audio help
Evening all
So on from my previous post regarding the static interference, I've noticed that if you move this white wire the interference either goes away or it gets worse. If you look at the top left corner there's an electric block used as a connection point. I'm pretty sure land rover wouldn't do this as their standard wiring. Anyone happen too know what this white wiring is for and why it would increase the static sounds. Other thing I wanted too find out is the device that these wires go into at the bottom, does anyone know what this unit is please.
Cheers all
Post #611091 30th Oct 2021 7:20pm
essex boy
Fibre optic cable i think if you need to look for a comparison i am local to you if you want to pm me
Post #611092 30th Oct 2021 7:39pm
Bean19844
Cheers pal. Any ideas what it's for. I think given the fact its got some dodgy connection block on it, its prob best its replaced regardless
Post #611094 30th Oct 2021 8:06pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Yes white wire is fibre cable, lower white wire has a proper bypass loop, 2003 didnt fiber have fiber so is car newer and you not updated profile ?
Post #611095 30th Oct 2021 8:08pm
Bean19844
Sorry mate should have said this is 2006 4.2
Post #611096 30th Oct 2021 8:12pm
Bean19844
What's the deal with the bypass loop?
Post #611097 30th Oct 2021 8:13pm
kds2
What ever it was pluged into doesnt work either hence bypass loop I would say.
Post #611098 30th Oct 2021 8:16pm
Kot
Surely no one is stupid enough to split a fibre cable and attempt to rejoin it with a electrical connection block Rolling with laughter Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #611099 30th Oct 2021 8:17pm
Bean19844
And yet the previous owner couldn't work out why there was interference in the radio. Tbh once you turn the volume up it drowns out the static sound but it's gotta be replaced....
OK so I hate too admit this chaps.
What does the fibre optic cable do?
Post #611100 30th Oct 2021 8:22pm
Kot
It transmits data around the Canbus
You need something like this that fits your cables note this is for BMW you need to get similar that fits LR systems maybe they are the same fibre size I dont know
https://www.ebay.co.uk/itm/153594653354?ha...SwTUZdSx-1 2018 SE SDV8 4.4 Byron Blue
Post #611102 30th Oct 2021 8:33pm
Bean19844
Kot
Tbh I'll just replace the whole loom. I'm not a fan of cutting and chopping wires or replacing them, that way I know its done.
Would this dodgy repair job possibly be the cause of the static interference
Post #611103 30th Oct 2021 8:43pm
Kot
You answered that question on your initial post Thumbs Up Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #611109 30th Oct 2021 9:05pm
Bean19844
Cheers pal
Post #611112 30th Oct 2021 9:43pm
Bean19844
And it's all rectified. Spent £44 on the cable and it works a treat. Sound system sounds so much better without the static interference so I'm happy with that. Took me all of 20 mins too change
Post #611723 5th Nov 2021 4:48pm
Kot
Well done Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #611783 6th Nov 2021 9:58am
