Home > In Car Electronics (L322) > Audio help |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 207 |
Fibre optic cable i think if you need to look for a comparison i am local to you if you want to pm me |
30th Oct 2021 7:39pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Cheers pal. Any ideas what it's for. I think given the fact its got some dodgy connection block on it, its prob best its replaced regardless |
30th Oct 2021 8:06pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 223 |
Yes white wire is fibre cable, lower white wire has a proper bypass loop, 2003 didnt fiber have fiber so is car newer and you not updated profile ? |
30th Oct 2021 8:08pm |
Sorry mate should have said this is 2006 4.2 |
30th Oct 2021 8:12pm |
What's the deal with the bypass loop? |
30th Oct 2021 8:13pm |
What ever it was pluged into doesnt work either hence bypass loop I would say. |
30th Oct 2021 8:16pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1245 |
Surely no one is stupid enough to split a fibre cable and attempt to rejoin it with a electrical connection block 2018 SE SDV8 4.4 Byron Blue |
30th Oct 2021 8:17pm |
And yet the previous owner couldn't work out why there was interference in the radio. Tbh once you turn the volume up it drowns out the static sound but it's gotta be replaced....
30th Oct 2021 8:22pm |
It transmits data around the Canbus
30th Oct 2021 8:33pm |
Kot
30th Oct 2021 8:43pm |
You answered that question on your initial post 2018 SE SDV8 4.4 Byron Blue |
30th Oct 2021 9:05pm |
Cheers pal |
30th Oct 2021 9:43pm |
And it's all rectified. Spent £44 on the cable and it works a treat. Sound system sounds so much better without the static interference so I'm happy with that. Took me all of 20 mins too change
5th Nov 2021 4:48pm |
Well done 2018 SE SDV8 4.4 Byron Blue |
6th Nov 2021 9:58am |
