Home > Technical (L322) > Turbo Failure - Symptoms? |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Unlikely to occur BUT if it did, huge amounts of black smoke, way down on power, potential engine runaway if oil leaking into inlet, engine management light on, faults galore logged. BMW i3 Electric Car
28th Oct 2021 6:49am |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
My symptoms were. A little black smoke, hardly any which was surprising, lack of power to the point of absolutely no power before engine stalled, would completely refuse to start, engine sounded like a bag of bolts on crank. On inspection one turbo had completely seized up and the other had oil passing through and was on its way out too. Both turbos replaced and all happy 2009 (2010 MY) 5.0 Supercharged Autobiography
28th Oct 2021 10:10am |
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 |
Thanks for that, with the exception of the noisy “nuts & bolts” symptoms are similar to mine. I’m going to look down that route. Thanks again. |
31st Oct 2021 11:08pm |
Champix Member Since: 07 Nov 2021 Location: Málaga Posts: 6 |
White smoke... oil burn |
7th Nov 2021 11:55pm |
