Home > Technical (L322) > Turbo Failure - Symptoms?
Kevhdkent
Can anyone describe the symptoms that would be experienced should a turbo seize and stop spinning ?
How likely, or unlikely, is this to occur ?
Post #610714 28th Oct 2021 6:08am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Unlikely to occur BUT if it did, huge amounts of black smoke, way down on power, potential engine runaway if oil leaking into inlet, engine management light on, faults galore logged. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #610718 28th Oct 2021 6:49am
TDV8 Paul
My symptoms were. A little black smoke, hardly any which was surprising, lack of power to the point of absolutely no power before engine stalled, would completely refuse to start, engine sounded like a bag of bolts on crank. On inspection one turbo had completely seized up and the other had oil passing through and was on its way out too. Both turbos replaced and all happy 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #610750 28th Oct 2021 10:10am
Kevhdkent
Thanks for that, with the exception of the noisy “nuts & bolts” symptoms are similar to mine. I’m going to look down that route. Thanks again.
Post #611245 31st Oct 2021 11:08pm
Champix
Spain 2009 Range Rover HSE TDV8 Barolo Black
White smoke... oil burn
Post #611958 7th Nov 2021 11:55pm
