Home > Maintenance & Mods (L322) > Oil Cooler Filter Housing 3.6 TDV8 - Is there a gasket here?
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hi all,
Can anyone confirm if there is a gasket between the cooler and the 'base' of the Oil Cooler Filter Housing on a 2010 3.6 TDV8 as shown in the pic below?
I know there's one for the whole assembly, but I have a coolant leak at the back to the 'V' which I'm trying to locate. Thermostat housing replaced and the Hose Assembly/Hoses all checked and appear fine - pressure test next - but just wondered about the gasket.....
UPDATE:
I may have answered my own question ? Just found this image on Ebay and to me ... Id say there was something there ....
Thanks, Gavin Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #610407 26th Oct 2021 11:59am
GraemeS
Yes there is a gasket but like the TDV6's cooler I haven't seen any reference for the gasket indicating that the gasket isn't available as a spare part, whereas the equivalent gasket for the 4.4's cooler is available as a spare part even though it wasn't initially.
Post #610484 26th Oct 2021 8:19pm
Superspoons
Thanks for confirming GraemeS Thumbs Up I asked Duckworth Parts this morning and yes, no gasket shown/available on Microcat.
I'll take it apart and take a look / reseal with an appropriate sealant. I've also just ordered LR002340 (the main gasket between the housing and engine) - there's really no point not doing it whilst I'm this far in and got it all apart.
 Gavin
Post #610561 27th Oct 2021 9:55am
GraemeS
When I changed my 4.4's gaskets I coated the new middle gasket with a high temperature silicone sealant. If your gasket doesn't disintegrate then perhaps that's an option for you.
Note that Microcat doesn't show the 4.4's gasket as a distinct item but now it is available so don't just rely on Microcat.
Post #610691 27th Oct 2021 8:29pm
Superspoons
Yes - I'll need to drop some of its oil and coolant though as I can imagine the two will mix if I removed just the cooler on its own.
I've bought some Granville Instant Gasket for this -
https://www.halfords.com/tools/garage-equi...TcEALw_wcB
I'm aiming to write this up for all fellow 3.6 owners who may need to do this in the future Gavin
Post #610726 28th Oct 2021 8:00am
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Pretty sure it’s 002342 - between the cooler and the base looking at the parts invoice from when I did this.
 2008/58 FFRR 3.6 TDV8 Vogue
Post #614813 5th Dec 2021 10:54am
