![]() | Home > Maintenance & Mods (L322) > Oil Cooler Filter Housing 3.6 TDV8 - Is there a gasket here? |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
Hi all,
Thanks for confirming GraemeS |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
When I changed my 4.4's gaskets I coated the new middle gasket with a high temperature silicone sealant. If your gasket doesn't disintegrate then perhaps that's an option for you.
Yes - I'll need to drop some of its oil and coolant though as I can imagine the two will mix if I removed just the cooler on its own.
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
Pretty sure it’s 002342 - between the cooler and the base looking at the parts invoice from when I did this.
