![]() | Home > Maintenance & Mods (L322) > L322 HID Bulb rating |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Worth knowing, typical though that the D3S is twice the price of the D2S |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
depends where you look for the bulbs...i have always got cheap 6000k bulbs of ebay and have never paid more than £20 for the pair..
I've bought Osram ones. £110 a pair. Christian.
KeithC Member Since: 16 Sep 2021 Location: Aberdeenshire Posts: 9 ![]() ![]() ![]() |
Caesium, are you doing the Osram night breaker upgrade o the H7 lamps at the same time to they are all whiter? |
I have ordered these HIDS:
Nice. Will they be okay through an MOT? |
The HIDS are a direct replacement and the main beam is not pattern tested. Christian.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Looks like it’s 35w that are fitted….
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
How do you find these? I was thinking about getting the same, along with the LED fog light bulbs too. Do you have any pictures you could share? Cheers |
You don’t need a high and low beam bulb for the H7… it doesn’t do high and low beam, so I imagine you’d be paying extra for a bit you don’t need….
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Those following this note cars 2006-2009 are fitted with D1S type. Worth checking what’s fitted before buying especially as the head lamps are so easy to remove, just a couple of screws holding the grill then 3 screws per headlamp 👍
Def 35w then……
Old bulb vs new bulb on a 2011
I recognise this picture ![]() Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
