Home > Maintenance & Mods (L322) > L322 HID Bulb rating
Page 2 of 3 <123>
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Worth knowing, typical though that the D3S is twice the price of the D2S Confused Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609597 18th Oct 2021 3:32pm
depends where you look for the bulbs...i have always got cheap 6000k bulbs of ebay and have never paid more than £20 for the pair..
some think the cheap ones are rubbish but i've had them in my td6,sc,westie and now my l405 and i've never had any problems. ... - .- -.
Post #609598 18th Oct 2021 3:56pm
Caesium
I've bought Osram ones. £110 a pair. Christian.
Current Cars
2019 BMW X4
or
Post #609600 18th Oct 2021 4:20pm
KeithC
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
Caesium, are you doing the Osram night breaker upgrade o the H7 lamps at the same time to they are all whiter?
Post #609606 18th Oct 2021 4:46pm
Caesium
I have ordered these HIDS:
https://www.amazon.co.uk/gp/product/B01NA9...&psc=1
and these H7 LED's to replace the main beam secondary bulbs.
https://www.amazon.co.uk/gp/product/B07P5N...&psc=1 Christian.
Current Cars
2019 BMW X4
or
Post #609608 18th Oct 2021 4:59pm
KeithC
Nice. Will they be okay through an MOT?
Post #609609 18th Oct 2021 5:04pm
Caesium
The HIDS are a direct replacement and the main beam is not pattern tested. Christian.
Current Cars
2019 BMW X4
or
Post #609613 18th Oct 2021 5:13pm
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
I put in 50w LED 6000k to replace the ds3’s. Came with large heat sinks and two small in line boxes which I tucked into the headlights. They must have rattled around and got in the way of the dynamic light mechanism and I got the flashing amber light on the dash. Looked at the front of the car and the lights were cross eyed! Should have stuck with the ds3 form factor. Anyway took them out and all when back to normal, could have been worse. Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #609649 18th Oct 2021 8:51pm
mjdronfield
Looks like it’s 35w that are fitted….
May have lifted this pic from elsewhere Whistle
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #609910 20th Oct 2021 8:29pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
How do you find these? I was thinking about getting the same, along with the LED fog light bulbs too. Do you have any pictures you could share?
Cheers
Post #609923 20th Oct 2021 9:15pm
mjdronfield
You don’t need a high and low beam bulb for the H7… it doesn’t do high and low beam, so I imagine you’d be paying extra for a bit you don’t need….
The H7 LED I fitted was just a single bulb.
Not sure I’d want them in the fogs as you have those on whilst you have oncoming cars, and not sure light pattern would be acceptable. Plus I’m not sure brighter light is what you need in fog…
I know you can get DRL units to replace the fog units, so light pattern there might be Ok for other drivers…
Just my 2p obviously. The standard fogs do look a bit pants compared to the other bulbs though.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #609925 20th Oct 2021 9:33pm
ur20v
A Trap
Those following this note cars 2006-2009 are fitted with D1S type. Worth checking what’s fitted before buying especially as the head lamps are so easy to remove, just a couple of screws holding the grill then 3 screws per headlamp 👍
Post #609958 21st Oct 2021 9:33am
mjdronfield
Def 35w then……
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #609961 21st Oct 2021 9:48am
Caesium
Old bulb vs new bulb on a 2011
 Christian.
Current Cars
2019 BMW X4
or
Post #609963 21st Oct 2021 10:11am
Caesium
I recognise this picture Laughing Christian.
Current Cars
2019 BMW X4
or
Post #609964 21st Oct 2021 10:12am
Page 2 of 3 <123>
