![]() | Home > Technical (L322) > HDC Fault - System Inactive - a new dreaded BONG |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
IIRC the cause of the car going to extended height when trying to lower is that it is taking too long and the car thinks it's on an obstruction. The remedy seems to be to check the exhaust silencer (filter) on the suspension compressor as it may be blocked, causing slow lowering. Drill a 2mm hole staight through it and try again.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
And don't forget most suspension faults are hard faults and need to be reset to clear the showing errors, not just fixed, so you may need a diagnostic tool that can sort out a fatty... |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 225 ![]() ![]() ![]() |
First off as suggested check the battery is charged low battery sends out all sorts of spurious warnings.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
Check for vacuum leaks too. PCV valve and the vacuum tube to the brake booster. |
GrunterNI Member Since: 30 Oct 2020 Location: Co Down Posts: 48 ![]() ![]() ![]() |
Thanks for all your replies guys. It really is appreciated |
Don't cheap out and use a flare instead. You're welcome ![]() Seriously though, get the IID. It's worth every penny ![]() |
Clobski Member Since: 21 May 2021 Location: Guildford Posts: 30 ![]() ![]() ![]() |
I’m just about to buy a Gap Diagnostics IID tool.. does any one know if there is a forum discount code or anything similar?? 2010 RR 4.4tdV8 Autobiography
Hi Grunter
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
For the height sensor I used OEM replacement (not original lr but looks identical) from island 4x4, and it works great |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 782 ![]() ![]() ![]() |
i need to save this info
