Home > Technical (L322) > Throttle position sensor part number?
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
Hi all, I think I need a replacement throttle position sensor.
The car intermittently goes into fault mode, IID shows a problem with circuit E of the throttle position sensor. Trouble is, it’s ok most of the time, but occasionally, every few days, it decides to behave like a pig.
It happened today, same error, but when I got home and examined the live values they look ok. But the voltage from circuit E does look a little ‘dirty’ compared to D.
So I’d like to replace the sensor - can someone give me the part number please?
I’m in Spain so I need the number - explaining it to a supplier doesn’t work very well!
Thanks
A.
Post #608864 11th Oct 2021 4:43pm
