Home > In Car Electronics (L322) > No ringtone for incoming calls
Mike220
As per the title, when I have an incoming call everything works perfectly aside from the fact there's no ringtone in the car to alert you of the call, so I've actually missed a couple as I hadn't seen the notification on the screen and answered it in time
Any ideas?
I've been through the settings and can't find anything, and tried the search function on the forum but it doesn't seem to be working
Cheers,
Michael 2011 Vogue SE Tdv8 FFRR
Post #608385 5th Oct 2021 7:48pm
mjdronfield
I’m not an expert, but that sounds more like an issue/setting on your mobile phone.
The L322 is just a Bluetooth headset.
Is your phone set to auto answer when a headset is connected or something similar?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #608394 5th Oct 2021 8:10pm
Mike220
No auto answer on at the moment. I can check phone settings but I thought the car "rang" for an incoming call too?
Has in every other car I've had, does the FF not ring? For instance if your phone was on silent, the car usually still rings to alert you of an incoming call (assuming it's paired to the car etc.) 2011 Vogue SE Tdv8 FFRR
Post #608395 5th Oct 2021 8:19pm
mjdronfield
Yes, it should ring, I just wondered if a phone setting would affect it.
Does it mute the radio when someone rings?
Or does it do nothing?
Can you ring out fine?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #608398 5th Oct 2021 8:22pm
Mike220
Yes it mutes the radio (if it's on) or any other audio playing at the time.
Makes and receives calls as it should, all controls work as they should.
I'm glad it's got you puzzled too - shows I'm not totally losing the plot (yet haha) 2011 Vogue SE Tdv8 FFRR
Post #608404 5th Oct 2021 8:35pm
Mike220
Car is 2011 vogue SE for reference 2011 Vogue SE Tdv8 FFRR
Post #608405 5th Oct 2021 8:36pm
AJGalaxy2012
What phone do you have?
Try this, when a call is incoming try using the volume + button on the steering wheel or the radio whilst its ringing. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #608419 6th Oct 2021 4:52am
Mike220
Pixel 5
That's a good idea, definitely one to try today - will feedback results later
Cheers 2011 Vogue SE Tdv8 FFRR
Post #608426 6th Oct 2021 6:45am
Baltic Blue
Have you solved it ??
My 2011 Vogue SE has also stopped ringing.
I get the ringing on the phone, so not a major problem, but it definitely used to ring on the car speakers.
My phone is an iphone7.
The only thing that could have changed, Apple are always doing software upgrades ??
I have recently been messing around with the car volume settings to get the Sat Nav voice a bit louder, but can’t think that should stop it getting incoming ring tones.
Post #608695 9th Oct 2021 8:25am
AJGalaxy2012
My BMW changes the ringtone volume with the cars volume controls, all the from 0 to deafening, try an incoming call and crank up the volume on the car controls.
j BMW i3 Electric Car
Post #608703 9th Oct 2021 9:26am
AJGalaxy2012
Any update? BMW i3 Electric Car
Post #609085 14th Oct 2021 3:29am
Westminster_Bri
I'd be curious for an update too... my IPhone 7 used to ring in the car with no issues (2012 Westminster) but having recently upgraded to an IPhone 12 it no longer rings. Calls work ok as stated by Michael, but without the ring a call is easily missed...
Clearly suggests a phone issue or setting, but who knows what it is!
Post #609087 14th Oct 2021 6:40am
Mike220
Sorry guys, been a crazy last week. I'll endeavour to try the suggestions today and let you all know
Post #609089 14th Oct 2021 7:20am
Baltic Blue
I have spent over an hour this afternoon trying different volume settings , test calls , phone settings, but it still doesn’t ring like it used to. Luckily my iPhone has a fairly loud ring so I can still answer incoming calls no problem, not that many people ring me these days …
Post #609500 17th Oct 2021 3:22pm
AJGalaxy2012
Under Settings>Do Not Disturb>DO NOT DISTURB WHILE DRIVING> make sure it is set on "Manually" and CARPLAY turned "OFF" BMW i3 Electric Car
Post #609502 17th Oct 2021 3:38pm
