![]() | Home > In Car Electronics (L322) > No ringtone for incoming calls |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I’m not an expert, but that sounds more like an issue/setting on your mobile phone.
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 ![]() ![]() |
No auto answer on at the moment. I can check phone settings but I thought the car "rang" for an incoming call too?
Yes, it should ring, I just wondered if a phone setting would affect it.
Yes it mutes the radio (if it's on) or any other audio playing at the time.
Car is 2011 vogue SE for reference 2011 Vogue SE Tdv8 FFRR |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
What phone do you have? Try this, when a call is incoming try using the volume + button on the steering wheel or the radio whilst its ringing. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
Pixel 5
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Have you solved it ??
My BMW changes the ringtone volume with the cars volume controls, all the from 0 to deafening, try an incoming call and crank up the volume on the car controls.
Any update? BMW i3 Electric Car
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 ![]() ![]() ![]() |
I'd be curious for an update too... my IPhone 7 used to ring in the car with no issues (2012 Westminster) but having recently upgraded to an IPhone 12 it no longer rings. Calls work ok as stated by Michael, but without the ring a call is easily missed...
Sorry guys, been a crazy last week. I'll endeavour to try the suggestions today and let you all know
I have spent over an hour this afternoon trying different volume settings , test calls , phone settings, but it still doesn’t ring like it used to. Luckily my iPhone has a fairly loud ring so I can still answer incoming calls no problem, not that many people ring me these days …
Under Settings>Do Not Disturb>DO NOT DISTURB WHILE DRIVING> make sure it is set on "Manually" and CARPLAY turned "OFF" BMW i3 Electric Car
