Home > Technical (L322) > Front windows automatically lower on engine start |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Pull the fuse for the windows... should stop them working...
4th Oct 2021 6:47pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1177 |
Apart from pulling the fuses, which is obviously a good idea -
4th Oct 2021 7:45pm |
RSW Member Since: 13 Oct 2015 Location: Devon Posts: 44 |
Could it be water has got into the switch pack on the drivers door? |
5th Oct 2021 7:09am |
Harrup Member Since: 01 Jan 2013 Location: Devon Posts: 25 |
Thank you all - great suggestions.
5th Oct 2021 7:35am |
Applying heat will make it worse, if you think it has suffered from water damage then you need to remove it and clean it with alcohol or similar, it is impurities in the water that are left after it dries that cause tracking across contacts, just heating it will not work and usually makes things worse...
5th Oct 2021 7:55am |
