Home > Maintenance & Mods (L322) > Suspension … |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Whilst I would not want to make accusations, it could be possible to catch the bag with a tool, it could also be that they raised the vehicle to off road height for access room and the bag just failed at that time.
30th Sep 2021 2:29pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
I had a bag blow when it was up on a scissor lift. You could clearly see it was past its best.
30th Sep 2021 2:50pm |
AJL322 Member Since: 08 Nov 2019 Location: Inverurie Posts: 22 |
Thanks Ill have a look at their kits |
30th Sep 2021 4:59pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
For the last few years as the weather gets colder we have seen a spate of front left suspension air bags go on 2010-2012 models
30th Sep 2021 11:13pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 743 |
+1 for just accepting that the bag has failed through old age.
30th Sep 2021 11:36pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
I have found that dirt/mud accumulates high up between the bag and the hard centre section which then rubs the bag eventually cutting little holes in the rubber. For vehicles that mainly stay on sealed surfaces I would expect the verge side one to be more exposed to dirt than the other. My vehicle which travels unsealed, often muddy roads accumulates grit on both sides. I now make a habit of regularly putting the suspension at super-extended height to hose out the dirt. |
1st Oct 2021 12:13am |
Sorry, I meant replacement bags, not repair kits per se. They do just the bag and so you can keep your strut https://www.advancedfactors.co.uk/front-ai...-292-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
1st Oct 2021 7:24am |
