Home > Technical (L405) > L405 lower tailgate problem
MonkeyMan
Hi Folks, odd one here that I cant find a specific answer to on older posts.
The power raise for the lower part of my tailgate just stopped working (2013 L405). pressing there button causes it to drop down smoothly, as usual, but pressing it to raise the tailgate gets some whirring noises from inside the car, but no activity. Trying to close via the top tailgate button or the remote does nothing, they dont response un less the lower tailgate is manually pushed closed. I do get a twin beep from the top tailgate button if I press t.
Tried to reset the tailgate by pressing the button for 20 seconds (tried on upper and lower buttons) but to no effect.
Any suggestions on anything else to try? I have about a week left on the warranty, so the timing is pretty good in that respect.
cheers!
Post #606899 20th Sep 2021 1:56pm
Watching
Sorry I can't help - mines been like that for a couple of years & I just kind of got used to manually closing the lower part.
Post #606907 20th Sep 2021 2:54pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Could this be the cause?
https://www.rangerovers.net/threads/range-...st-2347347
Post #606942 20th Sep 2021 7:21pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi try pushing lower tailgate button and while it is trying to shut manually push lower tail gate shut.
Then push upper tailgate button to close upper tailgate.
Then use key to open tailgates as per normal.
This should put all back in right order.
give it a go hope that fixes it.
Post #607030 22nd Sep 2021 1:22am
MonkeyMan
Jettec, that worked perfectly. thats amazing, many thanks!
Post #607045 22nd Sep 2021 10:44am
cager
United Arab Emirates 2017 Range Rover Vogue SE 5.0 SC V8 Santorini Black
This worked for me! Thank you.
I had a new battery replaced and when I got it back the bottom would close but I would get the beep beep. I followed this procedure and it worked again.
Post #695283 30th Jun 2024 8:36am
