Home > Technical (L322) > Ride height sensor - what have I done incorrectly?
Grayson Welly
Hello all,
L322 2006 Vogue AJV8.
At some point when the car was raised for a replacement starter motor, the ride height sensor snapped. The arm sits vertically and the connection between that and the swing arm at the base became disconnected. The initial indicator was that the OSF was sat alone at the raised height.
I superglued the two broken ends together (see photo) but after testing the different heights, the entire system has been deflated and is riding on the bump stops.
I'm not quite certain what has happened, but perhaps I should've disconnected the battery before fixing? Have I somehow messed with the calibration whilst grappling with the loose vertical rod, relative to the other corners?
My immediate aim is to replace the ride height sensor and see if that'll reset the system. However, as I am neither a regular mechanic nor experienced in this system, it's be great to have some guidance from those that might understand the system.
Post #606835 19th Sep 2021 9:50pm
Neilacker
Try disconnecting your battery and see if it resets 2010 tdv8 vogue se, Buckingham Blue
Post #606836 19th Sep 2021 10:10pm
Did you clear the faults, suspension faults tend to be hard faults and will only reset with a diagnostic tool.
Change the sensor as a glued one won't last long anyway, the plastic gets brittle with age...
Then reset faults and see what happens... Thumbs Up Pete
Post #606839 19th Sep 2021 10:24pm
Grayson Welly
Thanks guys.
I disconnected the battery with initial success. However, it is clear that there is a leak from the osf air bag.
My suspicion is that the compressor attempted to over-inflate the osf when the level sensor was detached, perhaps thinking that the height was too low (mis-reading) and perhaps may have blown the airbag in trying to over-inflate it? --------
2006 Buckingham Blue/Parchment White AJV8 Vogue
Post #606950 20th Sep 2021 8:59pm
Grayson Welly
I've ordered a replacement used height level sensor from Gentlemen of Salvage. We'll fit it and take it from there, hopefully the replacement will calibrate correctly (perhaps after a reset by disconnecting the battery) and resume correct function. --------
Post #607023 21st Sep 2021 10:41pm
