Home > Maintenance & Mods (L322) > Rear handbrake shoes adjuster siezed |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Try releasing fluid (lots e.g. wd40) with plenty of wiggling on the adjuster with a screwdriver or a bit of heat from a blowtorch. .
10th Sep 2021 8:09pm |
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 |
Tried wd40 with no luck but will maybe try some heat thanks 👍🏻 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
10th Sep 2021 8:10pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
One little trick, as the adjuster is splined, get a screwdriver with a hardened tip and the sort where the metal shaft goes all the way through the handle, then use that as a chisel to shock the adjuster, it may not be seized, it may be locked at the end of the travel. Seen that before.
10th Sep 2021 8:27pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
I would just try levering the disc off and hope. The handbrake shoes aren't expensive if you have to replace them.
10th Sep 2021 8:30pm |
Thanks I didn’t hammer it as I wasn’t sure if there was another way or technique but shocking it sounds like a good plan.
If you are planning to change the discs and pads, then it makes good sense to change the hand brake shoes at the same time, otherwise you could end up doing the job again a few months down the line, just seems logical to me to change everything in one go.
10th Sep 2021 8:47pm |
Never use the handbrake if I’m honest as it’s never been great, always assumed it needed adjusted and I would do it when changing the discs and pads.
10th Sep 2021 8:50pm |
When you get the disc off you will find it full of general crud which gets between the shoe surface and the drum surface effectively lubricating the contact surfaces.
10th Sep 2021 9:03pm |
Perfect mate, thanks for the advice. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
10th Sep 2021 9:14pm |
