Home > Maintenance & Mods (L322) > L322 Deep Clean without flattening the battery?
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
I part cleaned out our L322 today, thinking as the weather was sunny, I'd give it a good, thorough clean.
We have two large Pyrenean Mountain Dogs, so it does get dirty and to be done properly, ideally needs to completed over two days (today and tomorrow is the plan).
I spent about 3-4 hours on the interior today, with the doors open and radio on. When I came to start the car, it struggled but did start and left the dash with a yellow exclamation mark light on (This went off following a half an hour drive and engine restart).
My question is, other than leaving the engine running, how can I carry out this task without draining the battery.
I'm hoping to finish the job tomorrow, so any suggestions would be much appreciated.
Post #605837 7th Sep 2021 2:46pm
switch the interior lights off and dont have the radio on.. ... - .- -.
Post #605838 7th Sep 2021 2:48pm
mjdronfield
Yes, unfortunately it struggles to power the clock when left to it’s own devices 🤣
Turn the interior lights off, and no radio, as Stan says.
I put a music system in my garage to negate that issue….
Or perhaps a second battery installation…..
Not good though is it? Bring back the 2 litre Cortina….. wash with the 8 track on 🤣. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #605841 7th Sep 2021 3:06pm
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
How did you keep the radio on? Mine turns off after about 3 mins with a battery saver message even though it's fully charged. 2011 Vogue SE TDV8
Post #605842 7th Sep 2021 3:19pm
its year related i believe steve...the 2007 didnt have the '3 minute' shut off. ... - .- -.
Post #605843 7th Sep 2021 3:29pm
Connect a battery charger whilst you clean it. Thumbs Up
Post #605846 7th Sep 2021 3:54pm
Baltic Blue
If you have got a CTEK charger connect it and the battery will be fully charged by the time you have finished your deep clean. Thumbs Up
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #605847 7th Sep 2021 3:55pm
Baltic Blue
Rolling with laughter great minds etc nice day forit G reg 2.5VM Vogue Portofino red 1991- 1999
Post #605848 7th Sep 2021 3:56pm
aja500
Thanks to all for taking the time to reply, very much appreciated.
I do have three CTEK's but the connectors are for different vehicle manufacturers, so not sure they're compatible with Land Rover, or where I'd need to connect them on a L322.
I will try turning off the interior lights and leave the radio off tomorrow (amazed that such small things can drain a battery).
Thank you once again to all for taking the time to reply.
Post #605870 7th Sep 2021 7:46pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Depends what your vehicle specific leads are but pretty easy, either plug into cigarette lighter, crocodile clips on battery, 13 pin towing socket or I hard wire a lead for it to plug directly into.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #605873 7th Sep 2021 8:36pm
cass
How about disconnecting the -ve battery terminal?
Post #605885 7th Sep 2021 10:01pm
aja500
Thanks Rob and Cass, i'll take a closer look at both options tomorrow Thumbs Up Thumbs Up
Post #605887 7th Sep 2021 10:13pm
V8 Bob
Press and hold the central light switch in by the mirror for several seconds it knocks off all the interior and boot lights. Press it again and they come back on as normal. I have mine knocked off all summer due to the way FFRR’s can eat batteries. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #605890 8th Sep 2021 7:01am
aja500
That's good to know - Thanks Bob Thumbs Up Thumbs Up
Post #605893 8th Sep 2021 7:32am
DrRob
Disable interior lights and don’t use radio. Not ideal but only way without connecting a Ctek.
If you have towing electrics (13 pin or twin 7) then simply use a Ctek converter from the shop on here and job done Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #605894 8th Sep 2021 7:54am
