Home > Technical (L322) > Transmission hiccup 8spd
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
That's exactly why I was toying with the idea of trying a megaflush first. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #605818 7th Sep 2021 9:47am
Fox889
If it cures the fault, then money well spent. If it does nothing & the problem is much deeper, then you’ve just wasted £300-£400. Dilemma for sure. If that were me, I’d have Bodsy come down & mega flush it. Must admit, I haven’t read too much agro with these 8 speed boxes, that doesn’t help you though Confused 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #605819 7th Sep 2021 10:06am
4040
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
I have had similar on mine on rare occasions, in the same circumstances. Mines now on 72k and had the oil changed last year by a ZF approved specialist. He says under no circumstances do a flush according to ZF. It would be good to know what the truth of this is.
Post #605888 7th Sep 2021 10:27pm
JayGee
I'd suggest that a diagnosis from an auto gearbox specialist would be a lot cheaper than a megaflush.
Post #605898 8th Sep 2021 8:12am
rvbush
I doubt very much if there will be any faults logged. The symptoms are not bad by any means and most people probably wouldn't notice them (my Wife has never noticed). It's just a very gentle shudder on odd occasions that I know shouldn't be there. Drives:
Post #605924 8th Sep 2021 11:47am
JayGee
I would expect a diagnosis by an auto transmission specialist will involve more than just a fault code scan. They will be familiar with all kinds of drivability symptoms.
Post #605969 8th Sep 2021 5:32pm
coopss
rvbush wrote:
Can you let us all know if that helps please?
Oil level was fine. My prop centre bearing carrier is worn so it wobbles around - might be that 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #606155 11th Sep 2021 5:32am
