Home > Wheels & Tyres > Tyre Woes
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Tyre Woes
Cursed hidden pothole has created a small sidewall bulge in n/s rear tyre - no doubt an mot fail and for my own peace of mind it will be replaced asap. Tyres (Pirelli Scorpion Zero) are less than a year old and have tread remaining depth approx 7-8mm. Planning to fit a new Pirelli to replace the old cheap brand spare, and keep the damaged sidewall tyre as an emergency spare. I'm sure i read somewhere that tyres should be replaced in pairs on the same axle due to risk of damage to the diffs, but surely with 7-8mm depth remaining on the originals the new tyre tread radius difference will be negligible?
Please tell me I do not need two new tyres! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605404 2nd Sep 2021 12:59pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
If it’s damaged & in the spare it’ll fail an mot I believe.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #605406 2nd Sep 2021 1:05pm
Merchy
As the other tyre on that axle is relatively new with little wear, to me you only need one new tyre, not two.
As above, if the MOT tester can see the bulge in the wall, it will be an MOT fail. If the bulge faced down, you would probably get away with it, as I have never seen a tester remove the spare wheel for inspection, BUT.... would you want to drive on a motorway with a damaged tyre, Shocked best to change it.
Post #605407 2nd Sep 2021 1:13pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Think yourself lucky, I did the same with two new AT3's (only a week old) on my D3 when offroading on Fraser Island. Fortunately being in Australia we used to carry 2 spares.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #605408 2nd Sep 2021 1:18pm
RR2B
As far as I’m aware the spare is not checked during mot, but point taken. Maybe safer to keep the cheap-brand (undamaged) tyre as the spare after all. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605410 2nd Sep 2021 1:44pm
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Last few cars had before the RR didn't even have spare tyres. 2011 Vogue SE TDV8
Post #605411 2nd Sep 2021 2:02pm
not all cars have spares so leave the bulged tyre/wheel at home when you take yours for a MOT.. ... - .- -.
Post #605412 2nd Sep 2021 2:14pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Get them both replaced and chuck the current good used tyre in the spare wheel section
Post #605416 2nd Sep 2021 3:26pm
/\ That's what I'd do - 2 new tyres on - chuck the bulging one & use the other off the same axle as the spare.
But I acknowledge that I'm extravagant with tyres as I often drive long distances & want the piece of mind.
Post #605418 2nd Sep 2021 4:13pm
LT
^ That’s what I’d do. Tyres (and brakes) are just too important to economise on for the mileage that I do. Thumbs Up
Post #605610 4th Sep 2021 9:49pm
Fifth Horseman
Rob.
Wrong - from the MOT manual here
Quote:
5.2.3. Tyres
You only need to inspect the tyres fitted to the road wheels at the time of the inspection. If you notice a defect on a spare tyre, you should advise the vehicle presenter.
That is not to say however that it is ok to indefinatly carry a spare with a defect (although this in itself is not illegal) as if you were to then use it on a road wheel you would be committing an offence
Post #605741 6th Sep 2021 4:03pm
Chlorothalonil
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
Bulging tyre is 3 points plus a fine. Not suitable even as a spare.
Post #605783 6th Sep 2021 9:38pm
Sandyt
Either way a fine or not mot failure or not it is dangerous so get rid is my opinion and replace two and keep the one that is on the car without the bulge as spare as has already been said Thumbs Up For me tyres are too important to muck about with
Post #605899 8th Sep 2021 9:23am
RR2B
Sandyt wrote:
Either way a fine or not mot failure or not it is dangerous so get rid is my opinion and replace two and keep the one that is on the car without the bulge as spare as has already been said Thumbs Up For me tyres are too important to muck about with.
I eventually saw sense and have today done exactly this! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #606370 13th Sep 2021 6:01pm
