Home > Maintenance & Mods (L322) > 2012 4.4TDV8 Battery Charging Points - CTEK
DanPoole
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
Finally got round to putting the CTEK 7.0 onto the car today - not as simple as my old 4.4 V8 Petrol in terms of battery accessibility as the terminal nuts are captive, so trying to install a permanent CTEK attachment proved difficult (for me!).
This leads me to the question of - what are the best points to attach the positive and negative eyelets? I managed to attach to the positive on the battery, and then a possible earth, but after having charged for 4-5 or so hours on AGM setting (have AGM battery), and the CTEK unit showing battery nearly fully charged. When I disconnected, the comfort indicator was flashing red.
Have I done something wrong, or a dodgy charger unit?
Thanks
Post #604673 24th Aug 2021 4:55pm
rjff
Dan
Do you have 13 pin towbar electrics? If so you can use that.
Not sure on your other questions.
HTH Cheers
Richard
Gap IIDBT
Post #604676 24th Aug 2021 5:41pm
DanPoole
Thanks Richard.
I seem to have 2 x 7 pin plugs, but I read that they are not suitable as they don’t have direct battery connection (black cap, rather than white/grey?).
Post #604680 24th Aug 2021 5:57pm
mjdronfield
Been using the towing electrics for over 5 years with no issues with mine.
Got the adapter from the forum shop.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #604683 24th Aug 2021 6:07pm
rjff
Sorry about that Dan.
May be worth a check of the wiring in both your sockets to see if some kind soul has fitted 2 black instead of one black and one white/grey. Pin 4 is live battery and pin 3 is earth on the S type for use on the CTek etc.
http://www.uk-trailer-parts.co.uk/7-pin-s-type-caravan-wiring/
both wiring to pins on that link. Cheers
Richard
Gap IIDBT
Post #604684 24th Aug 2021 6:08pm
DanPoole
I also need to work out whether the charger is faulty before hand, as if my charging points were correct originally, the battery didn’t take any charge.
The battery has been fine, just used for a few short journeys recently, so thought I’d give it a quick charge as it wasn’t being used today.
Post #604685 24th Aug 2021 6:29pm
rjff
ISTR there are a couple of threads on here about connecting CTek and other chargers, if I find them I'll link. Particularly where to fit so as to be able to access a charging point when the battery is dead and you can't open the door. And that's another advantage of using the trailer electrics, connect, switch on and you have power to the doors etc.
But someone who has done so will be along soon to help. Cheers
Richard
Gap IIDBT
Post #604686 24th Aug 2021 6:44pm
DanPoole
Thanks Richard - I have searched but haven’t come across anything that looks similar!
Post #604687 24th Aug 2021 6:54pm
mjdronfield
I think my 2 plugs are white and grey.
I’m not a towist, so don’t know what that means, or what a black one does. Though from being a kid and my Grandad caravanning, one might be to charge a fridge 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #604688 24th Aug 2021 6:57pm
DanPoole
I believe black is for indicators etc, and white/grey is for caravan interior electrics.
No idea why I would have two black though! I’ve only had the car a month, so still learning!
Post #604691 24th Aug 2021 7:10pm
mjdronfield
You can see how much I know🤣, but done a quick google, and it seems there are 3 main types, black 7 pin, just the basic lights…. Then there’s that plug and another 7 pin, which seems to be white and does the added charging bits for a caravan battery and fridge constant supply etc…. Then there seems to be a more modern 13 pin that seems to have all that but in a single socket…. Which more modern caravans use… not sure what pins my 2 sockets are, but pretty sure I don’t have a black one….
https://www.pfjones.co.uk/advice-centre/to...trics.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #604692 24th Aug 2021 7:31pm
Your grey one may be faded black ?
It's the white one that is likely to have a permanent live.
The old UK system had a basic 7 pin black socket for trailers - with no permanent live. You could then add a second socket (AKA twin electrics) for all the stuff that a caravan needed - that included a permanent live.
As you stated, the European 13 pin combined both of the old UK sockets into a new single one.
Then along came the deployable tow bar on the L405 and you can't get to the electrics when it's stowed anyway Confused
Post #604693 24th Aug 2021 7:50pm
rjff
Dan
Enter CTek in the search function on here. Lot's of info.
You can use the earth points on the body under the bonnet with a lead from the battery +ve and a connector either under the bonnet or poking out from the grill. The former leaves you stufffed if the battery loses all charge. The latter at least allows a charger to give power to get into the vehicle. That is also an advantage of using the towing electrics. Cheers
Richard
Gap IIDBT
Post #604694 24th Aug 2021 8:09pm
mjdronfield
Good point Alistair…. It may well be faded…. Will look next time I’m out…
Well, I stoop corrected…. I was wrong, not happened since 1984 😱🤣🤣 I have black and white plugs with my factory fit tow bar…
White one used with my CTEK….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #604695 24th Aug 2021 8:10pm
DanPoole
@Alistair - any reason you know of why I would have two black plugs?
Post #604696 24th Aug 2021 8:13pm
