Home > Maintenance & Mods (L322) > 2012 4.4TDV8 Battery Charging Points - CTEK
I have no idea why there would be 2 black sockets. If you open the flaps & look at the pins inside - are the centre pins the same ?
Usually you should have a 12N & a 12S - 12N is the normal trailer connections & 12S is the supplementary caravan connections. AFAIK they are identical except for the centre pin - one has male, the other female.
There's loads of sites with the pin descriptions - example here and if you look at the pictures of a 12N & 12S plug you should see the difference in the centre pin.
Post #604711 25th Aug 2021 6:00am
DanPoole
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
Thanks Alistair - after checking the pins, I have the 12N and 12S plugs so have ordered the socket adapter for charging. Fingers crossed that works as looks a nice simple way to charge.
Post #604770 25th Aug 2021 6:05pm
mjdronfield
Will work fine mate. That’s what I use.
Means you can lock the car etc when charging without having to keep bonnet open etc.
Just need to remember to unplug it before you drive off 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #604777 25th Aug 2021 6:33pm
bishbosh10
Been there, done that - saw a long blue extension lead in my rear view mirror once when I had a RRC with a block heater in Canada... Whistle
My fix is to leave something on the driver's seat to remind you that the car is plugged in - the box / bag for the charger works well. Thumbs Up Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #604943 27th Aug 2021 12:26pm
mjdronfield
I put a little steel bin so it blocks the drivers door, as I go in my garage with the front of the car facing me…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #604948 27th Aug 2021 12:42pm
