Home > Technical (L322) > PO033-00 (2F)
Baltic Blue
PO033-00 (2F)
I have got 2 faults permanently showing on my iid.
They have both been present for several years, but since the car is running well, I have just accepted them.
The second is the well documented EGR sensor fault that Greg has told us all how to fix, but it is the first fault that I am trying to sort.
The CSOV valve was replaced before the fault appeared and is still in good working order.
Any ideas ??
Post #603729 13th Aug 2021 9:42pm
Baltic Blue
The W.M. says….
Boost air re circulation solenoid ????
I can’t find any other mention of it and haven’t got a clue where it could be, or what it does.
Post #603870 15th Aug 2021 8:49pm
Mike, i put 'Boost air re circulation solenoid' into google and it came up with a fair bit of info..way over my understanding of engines but probably you'd know.. ... - .- -.
Post #603872 15th Aug 2021 9:15pm
Baltic Blue
Thanks Stan,
Plenty of reading for me this morning.
Post #603890 16th Aug 2021 7:30am
Baltic Blue
Stan, you have cracked it, my hero Bow down Bow down
Having read several posts on Google, I have now recognised the solenoid and know exactly what the problem is.
Main dealers , Big Cry Big Cry
I can actually see the problem, but have just got to work out how to get to it to fix it.
I can’t even get a decent photo, but this will help me explain…..
At the very top of the picture you will see the shiny new CSOV valve that was replaced under warranty when the original was jammed stuck and causing restricted performance.
The solenoid is just to the left of it and the electrical socket can be seen with no plug in it.
The harness is very short and I can see the plug that they either forgot to re-fit or it has fell off.
I just need to work out how to reconnect it.
Probably going to have to get it up high, remove the undertray and hopefully hook something round the plug and pull it back into the socket.
Post #603990 17th Aug 2021 11:34am
i wondered where you'd been for the last couple of days.. Laughing
Thumbs Up ... - .- -.
Post #603992 17th Aug 2021 11:42am
Baltic Blue
Update / correction…
It isn’t a very short wire, in fact quite a bit of slack that was trapped.
I have managed to free it using a telescopic rod, but I can’t make anything suitable to re- connect it and I am not sure what I will gain when I get the undertray off, but that will have to wait until the weather improves .
Mike
Edit… hint Stan it would be clearer if the picture was rotated 90 anti-clockwise. Please. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #603994 17th Aug 2021 2:23pm
DrRob
Use one of those long reach gripping tools maybe? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #603996 17th Aug 2021 2:53pm
Baltic Blue
I have just been looking on eBay Rob, but haven’t seen anything suitable yet. The plug is about 5/8” wide.
Post #603998 17th Aug 2021 3:00pm
Rolling Eyes Wink ... - .- -.
Post #604002 17th Aug 2021 3:45pm
Rambles
Did you change the full CSOV or just the actuator ?
Post #604003 17th Aug 2021 3:51pm
Baltic Blue
The whole unit was changed by the supplying MD under warranty, 4-5 years ago.
Post #604004 17th Aug 2021 3:57pm
Baltic Blue
Rob,
I have just ordered a flexible 24” long grabber off eBay.
Not sure it will work, but worth a try.
Post #604005 17th Aug 2021 4:04pm
Baltic Blue
You are a gentleman Stan Thumbs Up
Post #604006 17th Aug 2021 4:11pm
DrRob
Good luck grabbing Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #604015 17th Aug 2021 5:29pm
