![]() | Home > Technical (L322) > PO033-00 (2F) |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
I have got 2 faults permanently showing on my iid. They have both been present for several years, but since the car is running well, I have just accepted them. The second is the well documented EGR sensor fault that Greg has told us all how to fix, but it is the first fault that I am trying to sort. The CSOV valve was replaced before the fault appeared and is still in good working order. Any ideas ?? Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
The W.M. says….
Boost air re circulation solenoid ???? I can’t find any other mention of it and haven’t got a clue where it could be, or what it does. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
Mike, i put 'Boost air re circulation solenoid' into google and it came up with a fair bit of info..way over my understanding of engines but probably you'd know.. ... - .- -.
Thanks Stan,
Stan, you have cracked it, my hero
At the very top of the picture you will see the shiny new CSOV valve that was replaced under warranty when the original was jammed stuck and causing restricted performance. The solenoid is just to the left of it and the electrical socket can be seen with no plug in it. The harness is very short and I can see the plug that they either forgot to re-fit or it has fell off. I just need to work out how to reconnect it. Probably going to have to get it up high, remove the undertray and hopefully hook something round the plug and pull it back into the socket. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
i wondered where you'd been for the last couple of days.. |
Update / correction…
Mike Edit… hint Stan it would be clearer if the picture was rotated 90 anti-clockwise. Please. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Use one of those long reach gripping tools maybe? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I have just been looking on eBay Rob, but haven’t seen anything suitable yet. The plug is about 5/8” wide.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Did you change the full CSOV or just the actuator ? |
The whole unit was changed by the supplying MD under warranty, 4-5 years ago.
Rob,
You are a gentleman Stan |
Good luck grabbing |
