![]() | Home > Maintenance & Mods (L322) > What's best to clean grubby boot cover/parcel shelf? |
I had the same issue with a sand coloured one. I used washing powder / hot water mix with a soft brush and also some Vanish. Then I used the wet vac to dry it off. Repeated a couple of times on stubborn stains. Not perfect but a lot better than it was.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3873 ![]() ![]() ![]() |
Mine is sand as well, this is what I did.
1001 dry foam a really good scrub and rinsed off with a hose |
Depending on how grubby your shelf is I have used AutoSmart Brisk Dry Foam very good indeed. It's great for the headlining too as it doesnt over-wet the surface. Smells great too!
manfrommissenden Member Since: 23 May 2011 Location: Bucks Posts: 4 ![]() ![]() |
Gents, thanks very much for the tips.
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
always use STARDROPS its the UK version of the greeks windex |
jammyk Member Since: 12 May 2011 Location: Oxfordshire Posts: 17 ![]() ![]() ![]() |
With a cream interior i keep baby wipes in the car. These are used very sucessfully in cleaning the parcel shelf. little elbow grease required and drys very quickly! |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3763 ![]() ![]() |
+1, and seats, pants, dashboard, steering wheel, console - oh and babies |
