Home > Maintenance & Mods (L322) > Front & Rear Discs & Pads Change
Wiggins
2011 Range Rover Autobiography 4.4 V8 Santorini Black
Hi there, bought new discs and pads for the RR because I had a Vehicle Health Check done at Land Rover and I'm to tight to pay for them to do it so going to do it myself, I have change Ds & Ps on many cars before but just wondering if anyone could tell me what tools are needed so I can get hold of them during the week to carry out the work at the weekend, if anyone could help would be great
Post #65348 23rd May 2011 10:39am
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i haven't done this yet as mine had all new on when i bought it, but i should imagine it will be fairly straight forward and a socket set, a screwdriver of suitable size to take screw from disc and maybe a windback tool to make pushing the pistons back a bit easier.
no doubt someone will correct me if my assumptions are wrong!!
when you have done it maybe worth letting us all know for future reference.
i should imagine it will only take about an hour to do. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65377 23rd May 2011 1:14pm
RANGEROVER
England 2003 Range Rover SE Td6 Zambezi Silver
http://www.fullfatrr.com/forum/post58491.html#58491
Quote:
pad wear sensor mine was corroded to the old pad and I would always change anyway.
Rear handbrake shoes really should be replaced I did'nt though may end up doing them...
7mm allen key is required to remove the rear caliper from carrier.
I bought a proper long handled one from Halfords and cut it down to fit @ £7
Also a 6mm Hex - 3/8 socket bit to get the disc off the hub a 6mm allen key may get it off but could'nt mine.
16mm socket required to remove carrier.
Post #65383 23rd May 2011 2:00pm
there are a few yubey tubey videos on this..
Post #65386 23rd May 2011 2:26pm
dan_uk_1984
Certainly one of the easier jobs one can do in terms of Pads, but personally I had great trouble getting my discs off. You should have a big hammer to hand, and of course decent axle stands.
If your handbrake isn't 100% then this is the time to do that too, there is a set of handbrake shoes on eBay for £25 which is a bargain.
http://cgi.ebay.co.uk/RANGE-ROVER-L322-VOG...35b0bc7632
Post #65391 23rd May 2011 2:48pm
Wiggins
thanks alot lads! going to get it cracked tomorrow, give the minging calipers a lick of paint, post a few pics Smile
Post #65490 23rd May 2011 9:22pm
tilemanvogue
England 2004 Range Rover Vogue 4.4 V8 Alveston Red
Re: Front & Rear Discs & Pads Change
Hi Wiggins
I have just done that with mine, you will need an allen key to remove the callipers, thought it was a star socket first, but no (you probably know this) but found it very easy, hope this helps Discovery 3.9
Range Rover 4.6 HSE 1998
L322 Range Rover Vogue 4.4 2004
Post #65847 26th May 2011 12:55pm
mzplcg
If you're taking off rear discs then remember to back off the handbrake adjusters beforehand. If you have EPB (as opposed to a proper lever) then remember to put in service mode 1st. If that applies for any reason whilst you're working on it, it can remove fingers etc.
Download a copy of Bodsy's Brake Bible from here
http://www.disco3.co.uk/gallery/displayima...&pos=4
Written for a D3 but ostensibly the same as a FFRR.
Dom
Post #65848 26th May 2011 1:01pm
...and take the opportunity to adjust your handbrake so you dont have to pull it all the way up for it to engage.
Post #65849 26th May 2011 1:10pm
Wiggins
Got them all done today, didn't have a 7mm allen key socket small enough so just took off the carrier to get into it, tightened handbrake, gave the brakes a good bleed and car feels like brand new, the grooved and drilled discs look brilliant also with a good lick of paint makes it look 100 times better
Thanks for the help guys Smile
Post #65850 26th May 2011 1:16pm
