![]() | Home > Maintenance & Mods (L322) > Front & Rear Discs & Pads Change |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
i haven't done this yet as mine had all new on when i bought it, but i should imagine it will be fairly straight forward and a socket set, a screwdriver of suitable size to take screw from disc and maybe a windback tool to make pushing the pistons back a bit easier.
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/post58491.html#58491
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
there are a few yubey tubey videos on this.. |
Certainly one of the easier jobs one can do in terms of Pads, but personally I had great trouble getting my discs off. You should have a big hammer to hand, and of course decent axle stands.
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 ![]() ![]() |
thanks alot lads! going to get it cracked tomorrow, give the minging calipers a lick of paint, post a few pics |
tilemanvogue Member Since: 22 May 2011 Location: Aylesbury Posts: 24 ![]() ![]() ![]() |
Hi Wiggins I have just done that with mine, you will need an allen key to remove the callipers, thought it was a star socket first, but no (you probably know this) but found it very easy, hope this helps Discovery 3.9 Range Rover 4.6 HSE 1998 L322 Range Rover Vogue 4.4 2004 |
If you're taking off rear discs then remember to back off the handbrake adjusters beforehand. If you have EPB (as opposed to a proper lever) then remember to put in service mode 1st. If that applies for any reason whilst you're working on it, it can remove fingers etc.
...and take the opportunity to adjust your handbrake so you dont have to pull it all the way up for it to engage. |
Got them all done today, didn't have a 7mm allen key socket small enough so just took off the carrier to get into it, tightened handbrake, gave the brakes a good bleed and car feels like brand new, the grooved and drilled discs look brilliant also with a good lick of paint makes it look 100 times better
