Home > Technical (L322) > Suspension calibration IID Tool - How to guide?
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi, I have the IID just last week & would like to first try to calibrate my suspension before i order any height sensors.
Is there any how to guides? Also what measurements do I use, I have 22s 275/40/22 fitted? 2004 RR 4.4 V8 Autobiography
Post #603265 9th Aug 2021 12:50pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi Mate check out the wiki or go on Gap web site?
Post #603268 9th Aug 2021 1:08pm
PaulM
Thanks, good idea. I’ll look on gap as I checked wiki & couldn’t see anything to do with suspension calibration. 2004 RR 4.4 V8 Autobiography
Post #603272 9th Aug 2021 1:35pm
Tyre/wheel size is irrelevant, you measure from the centre of the wheel to the top of the wheel arch so tyre/wheel size has no bearing.. Thumbs Up Pete
Post #603275 9th Aug 2021 2:00pm
Tinman
Hi Paul, it`s down the bottom of the Wiki: DOWNLOAD & REPAIR VIDEO LINKS.
Post #603280 9th Aug 2021 3:14pm
PaulM
Ok well I’ve had a little go but my brain couldn’t understand the gap instructions 😬
So what I did was just measure 500mm from Center of the wheel to the arch lip & adjusted the heights so all 4 were the same. It’s all pretty level now as before my drivers side front was down about 30mm from passenger side front & I think that was causing the articulation validity fault. Seems to be ok at the min but I will look at it properly again.
Before I did they were as follows.
O/S/F 490mm
N/S/F 520mm
O/S/R 500mm
N/S/R 510mm 2004 RR 4.4 V8 Autobiography
Post #603330 9th Aug 2021 11:26pm
