![]() | Home > General > What Did You Do In Your Full Fat Today |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 ![]() ![]() |
Had 2 front tyres replaced, which had sneakily worn down to the canvass on the inside edges |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 ![]() ![]() ![]() |
Bought a new battery as the 8 year old original decided to die this morning |
dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127 ![]() ![]() ![]() |
Took mine for mot this morning, passed with no problems.
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Mustard - I have same issue, drivers side inner edge
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I've used a couple of garages recommended on the site below for 4 wheel alignment over the years - all have done a great job for £100 or less
Yes the tyre people said my tracking is way off and thats why its happened so I had it done by them, I have got a print off of all the adjustment sizes that were made on the 'supertracker' machine. Because I bought the tyres off them they did the alignment for £30 but my friend has just had his done at a different place for £50 so Im guessing it wont cost you too much. Im in the north west so the places I used wont be available to you in London. I had only measured all my tyre tread depths 2 weeks ago and its dam annoying as I had good tread left on the tyres. Ill be keeping a close eye on these 'Continental Cross Contacts' for any signs of uneven wear as thats one expense I can do without ![]() |
Cheers both, will get it done. Found a place literally round the corner using that website above |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35522 ![]() ![]() |
back on topic, i watched mine get very wet.... ... - .- -.
Raised the suspension to full height while SWMBO was in the shop and then watched her struggle to get in |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Just had it cleaned and now its Pi55ing down |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Drove to work, once I could find the road.
Luxury4Paul Member Since: 16 Mar 2012 Location: New Jersey Posts: 119 ![]() ![]() ![]() |
I woke up this Christmas morning and looked at the sunrise and thought....haha I drive a pink Range Rover. |
nightster1 Member Since: 26 Feb 2012 Location: Cork Posts: 14 ![]() ![]() ![]() |
my TD6 is €1495........not to bad for a year's pleasure! Current:- TD6 HSE Past:- Jeep Grand Cherokee Limited CRD x2 Jeep Cherokee Limited TD x1 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8697 ![]() ![]() ![]() |
Drove 2 miles drove 2 miles back again. If i keep this up i will have to put it on charge! There is nothing that can't be fixed with a hammer😜😜
